I am sure this is not the first about rotella oil
   / I am sure this is not the first about rotella oil #1
DDT
Platinum Member
Clay Center, Kansas
Kubota M6040/cab, BX25D, RTVX900
I have been useing JD plus 50 oil in my JD tractor and my dodge 1 ton (cummins engine) I went to a Kubota tractor since my dealer wanted to play list price game any way I don't feel I should keep buying all the oils from JD now. I am looking for another oil that I can use in my truck and tractor. I can get Rottella in a 55 gal drum for $329. I prefer the drum, since it will last a year. Any pro's or con's on this oil. If it works out good I would also use it in my wifes chevy avachahe ( I can't spell that one). Or I could go to my local coop under centex brand? I don't mean to start a war I just don't know which way to go.
   / I am sure this is not the first about rotella oil #2
Rotella is good oil. I don't think the Avalanche probably lists 15w-40 among the preferred grades, however.
   / I am sure this is not the first about rotella oil #3
DDT,
<font color="green">Shell Rotella</font> is a good oil. We used it exclusively in the oilfield when I worked in the oilfield. Those engines see severe useage sometimes for days on end without shutdown. Quite often at full throttle running pumps and such. Another good oil is <font color="blue">Chevron's Delo 400</font>. This is a favorite of a lot of over-the-road truckers. Buy it by price, just change your oil at the recommended interval.
Thanks for the delo link, I have a NAPA 1/2 block from me. I will price them as well.
   / I am sure this is not the first about rotella oil #5
I use rotella in every diesel I own. We have been doing it for many years and no problems at all. You can buy it from Sam's Club for $270 for 55 gallon drum. Farm and Fleet also has it for around the same price.
   / I am sure this is not the first about rotella oil #6
<font color="blue"> I can get Rottella in a 55 gal drum for $329. </font>
<font color="blue"> You can buy it from Sam's Club for $270 for 55 gallon drum. </font>
That's a big price difference if it's the same. G
I tryed to get on sams web site and had no luck, it was running very very slow. Will sams have prices posted there?
   / I am sure this is not the first about rotella oil #8
I've never been to the Sam's website so I couldn't tell you about that. I'm sure the prices are the same all across the country.
Yes Gerard it's the same Rotella.
   / I am sure this is not the first about rotella oil #9
I just checked on the website and for some reason it doesn't show the 55 gallon drums. On the website you can find the closest Sam's Club to you. Just call them and see how much it goes for.
Thanks for the lead. Sams do have it in the drum for $273.
2020 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A52377)
2020 Caterpillar...
2017 TRAILSTART 40FT DUMP TRAILER (A54607)
2017 TRAILSTART...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
2006 Nissan Titan Crew Cab Pickup Truck (A53422)
2006 Nissan Titan...
