I added 3 diverters, top-n-tilt & aux w/ tank drain
   / I added 3 diverters, top-n-tilt & aux w/ tank drain #1
ksJoe
Andover, Ks
New Holland Boomer 30
I brought my tractor home (from the rural property) for a few weeks while I sorted out some modifications.
I added a diverter on the front loader, with a tank drain
To plumb the tank drain, I brazed on an existing tank drain line. I brazed the bung on first, then drilled the hole though the tubing. That seemed like the better thing to do, avoiding contamination of the weld and avoiding alignment issues.
I added 2 diverters on the existing rear remote:
I used a regular ($60) cylinder for the side tilt, but had to make a swivel for the top and bushings for the bottom.
The rear diverters also have a tank driain plumbed to them, but I didn't put a quick couple on it because I currently don't have any rear attachments that would use a tank drain.
Its tight on the back, but I found a position for the top link cylinder where it doesn't smash anything.
   / I added 3 diverters, top-n-tilt & aux w/ tank drain #2
Tank drain is a good idea that is not often thought of in the compact tractor world. You did a nice job installing the valves.
   / I added 3 diverters, top-n-tilt & aux w/ tank drain #3
Why add a tank drain?
   / I added 3 diverters, top-n-tilt & aux w/ tank drain #5
Some diverters have a operating pressure limit without external drain. External drain also allows use of manual override if diverter has this option.
Many hydraulic motors need a tank drain. There will be some internal leakage in the motor. If the drain is plugged, pressure will build and it can blow the motor's seal around the shaft. With a tank drain, any internal leakage is safely diverted back to the tank.
A while back I made a hydraulic post hole digger (see post). That motor on it has a tank drain. I've used it a little without the drain connected, but it was shipped with a weak plastic dust plug in the drain. So I thought the plug would leak if needed. I asked them if the drain is required (because some manufacturers say you can plug the drain), but Surplus Center told me not to plug it.
   / I added 3 diverters, top-n-tilt & aux w/ tank drain #7
Yup, Lane Shark now wants a separate return to sump line installed for their hydraulic motors. Just had the install done a couple weeks ago. I think their reasoning was to keep hot hydraulic fluid from flowing directly back through the 3rd function valve.
City of Buckhannon -Onan 50 Set Stand By Generator (A52384)
City of Buckhannon...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 84"...
1996 International 4700 Box Truck, VIN # 1HTSCABP2TH265415 (A51572)
1996 International...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A53472)
Kubota 24in Quick...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
(2) 300 GALLON POLY TOTE (A51248)
(2) 300 GALLON...
