HyTran Ultra= Multi-G 134 Fluid?
   / HyTran Ultra= Multi-G 134 Fluid? #1
Doc_Bob
Elite Member
Wisconsin
2003 NH TN70A
Folks, NH and Case are one and the same. Blue tractor, Red tractor.
Now, below are two hydraulic fluids. For a NH TN70A, the local Case Dealer says the HyTran Ultra Tractor Fluid will work fine in the NH power shuttle 16x16. Now, NH lists their Multi-G 134 Fluid (NH-410B). I thought it would be a good idea to ask, is the Case dealer correct? Will the Hy-tran fluid be acceptable in the NH TN70A tranny? Or should I go with the Multi-G 134 Fluid (NH-410B)?
Multi-Purpose hydraulic / transmission fluid
Thoroughly tested and approved by CNH engineering. Meets NH specification NH-410B.
A unique all-weather hydraulic/transmission fluid
Thoroughly tested and approved by CNH engineering. Meets Case specification MS-1209
I came up with some thoughts. Why I should not use Hytran Ultra in a NH with Multi-G 134 Fluid. You can never remove all the tranny fluid. Some Multi-G 134 Fluid will remain in the tranny. So, if changing old Multi-G 134 Fluid and then mixing new Hytran Ultra in with old Multi-G 134 Fluid, will there be a mismatch? Especially if the Multi-G 134 Fluid is 4 years old and the Hytran Ultra is new. I assume (just an assumption) that additive package change over time in the Hytran Ultra. Then the Hytran Ultra may have some new additives that the 4 year old Multi-G 134 Fluid never anticipated. Unlikely, but with a 10K tranny, do I feel lucky?
Just some thoughts.
Bob
Just some thoughts.
Bob
   / HyTran Ultra= Multi-G 134 Fluid? #7
IMO , why take the chance. Is there a HUGE price difference?
I use only CNH products in my TC29; If I ever have a problem, CNH can't say , The product you used caused the problem!
</font><font color="blue" class="small">( IMO , why take the chance. Is there a HUGE price difference?
I use only CNH products in my TC29; If I ever have a problem, CNH can't say , The product you used caused the problem! )</font>
Closer to Case dealer versus NH. But you are correct, why take the risk? Better to drive a few more miles. Thanks for the comments.
I have learned, after numerous emails, that Hytran and Multi-G134 are NOT compatible. Should not be mixed.
Bob
UNUSED IRANCH HYD EXCAVATOR THUMB CLAMP (A54757)
UNUSED IRANCH HYD...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
2011 INTERNATIONAL DURASTAR 4400 (A53843)
2011 INTERNATIONAL...
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A52377)
2014 Ford F-450...
2004 Caterpillar 345B Hydraulic Excavator (A53421)
2004 Caterpillar...
