HyTran Ultra= Multi-G 134 Fluid?
   / HyTran Ultra= Multi-G 134 Fluid? #1
Doc_Bob
Elite Member
Wisconsin
2003 NH TN70A
Folks, NH and Case are one and the same. Blue tractor, Red tractor.
Now, below are two hydraulic fluids. For a NH TN70A, the local Case Dealer says the HyTran Ultra Tractor Fluid will work fine in the NH power shuttle 16x16. Now, NH lists their Multi-G 134 Fluid (NH-410B). I thought it would be a good idea to ask, is the Case dealer correct? Will the Hy-tran fluid be acceptable in the NH TN70A tranny? Or should I go with the Multi-G 134 Fluid (NH-410B)?
Multi-Purpose hydraulic / transmission fluid
Thoroughly tested and approved by CNH engineering. Meets NH specification NH-410B.
A unique all-weather hydraulic/transmission fluid
Thoroughly tested and approved by CNH engineering. Meets Case specification MS-1209
I came up with some thoughts. Why I should not use Hytran Ultra in a NH with Multi-G 134 Fluid. You can never remove all the tranny fluid. Some Multi-G 134 Fluid will remain in the tranny. So, if changing old Multi-G 134 Fluid and then mixing new Hytran Ultra in with old Multi-G 134 Fluid, will there be a mismatch? Especially if the Multi-G 134 Fluid is 4 years old and the Hytran Ultra is new. I assume (just an assumption) that additive package change over time in the Hytran Ultra. Then the Hytran Ultra may have some new additives that the 4 year old Multi-G 134 Fluid never anticipated. Unlikely, but with a 10K tranny, do I feel lucky?
Just some thoughts.
Bob
Just some thoughts.
Bob
   / HyTran Ultra= Multi-G 134 Fluid? #7
IMO , why take the chance. Is there a HUGE price difference?
I use only CNH products in my TC29; If I ever have a problem, CNH can't say , The product you used caused the problem!
</font><font color="blue" class="small">( IMO , why take the chance. Is there a HUGE price difference?
I use only CNH products in my TC29; If I ever have a problem, CNH can't say , The product you used caused the problem! )</font>
Closer to Case dealer versus NH. But you are correct, why take the risk? Better to drive a few more miles. Thanks for the comments.
I have learned, after numerous emails, that Hytran and Multi-G134 are NOT compatible. Should not be mixed.
Bob
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
2017 KOMATSU PC290LC-11 EXCAVATOR (A52706)
2017 KOMATSU...
2016 Kubota SVL 75-2 (A47477)
2016 Kubota SVL...
UNUSED 72" HYD ROCK GRAPPLE BUCKET (A54757)
UNUSED 72" HYD...
2007 Hyundai Sonata GLS Sedan (A51694)
2007 Hyundai...
