Hyster 50 forklift
   / Hyster 50 forklift #1
AllanSw
Healesville Victoria Australia
Hyster 50 forklift
I have a Hyster 50 forklift with a blown head gasket and I cant find out what make of engine it has in it?
It has D6JL 6015 B cast into the engine block just above the sump on the distributor side
Any help to identify it would be appreciated.:)
   / Hyster 50 forklift #2
Several versions of model 50 - I'm assuming from your distributor comment it's Gasoline? Looks like it might be a Mazda engine
403 Request Blocked (I know it says request blocked, but the link works)
Some also had Perkins diesels, seen a few Continentals as well but don't know if they were same model as yours or not.
Good luck... Steve
   / Hyster 50 forklift #3
The 6015b casting number leads me to believe its a ford motor.
   / Hyster 50 forklift #4
The model letter at the end might give an indication of what engine was used; I have a Hyster H50 H which has the Continental. You might be able to find info with the model designation letter, but I've found that it's pretty difficult to find stuff online for them. You might have to resort to having a dealer do a serial number search, depends on how loose he is with info on whether you'll just get a Hyster p/n or some useable cross info.
   / Hyster 50 forklift #6
You can try posting your request over on the forums at forkliftaction.com. They have a couple areas where guys who really know the lifts will answer questions. The answer may already be there, also.
CATERPILLAR 140M2 MOTOR GRADER (A52706)
CATERPILLAR 140M2...
1999 CLEMENT END DUMP (A53843)
1999 CLEMENT END...
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2018 FREIGHTLINER...
2006 CHEVROLET EXPRESS SERVICE VAN (A54313)
2006 CHEVROLET...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
