Hyster 50 forklift
   / Hyster 50 forklift #1
AllanSw
Healesville Victoria Australia
Hyster 50 forklift
I have a Hyster 50 forklift with a blown head gasket and I cant find out what make of engine it has in it?
It has D6JL 6015 B cast into the engine block just above the sump on the distributor side
Any help to identify it would be appreciated.:)
   / Hyster 50 forklift #2
Several versions of model 50 - I'm assuming from your distributor comment it's Gasoline? Looks like it might be a Mazda engine
403 Request Blocked (I know it says request blocked, but the link works)
Some also had Perkins diesels, seen a few Continentals as well but don't know if they were same model as yours or not.
Good luck... Steve
   / Hyster 50 forklift #3
The 6015b casting number leads me to believe its a ford motor.
   / Hyster 50 forklift #4
The model letter at the end might give an indication of what engine was used; I have a Hyster H50 H which has the Continental. You might be able to find info with the model designation letter, but I've found that it's pretty difficult to find stuff online for them. You might have to resort to having a dealer do a serial number search, depends on how loose he is with info on whether you'll just get a Hyster p/n or some useable cross info.
   / Hyster 50 forklift #6
You can try posting your request over on the forums at forkliftaction.com. They have a couple areas where guys who really know the lifts will answer questions. The answer may already be there, also.
LINDE WELDER (A53843)
KMC 5610 (A53084)
KMC 5610 (A53084)
2020 Deere 325G (A50123)
2020 Deere 325G...
2022 BOBCAT S64 COMPACT SKID STEER LOADER (A53473)
2022 BOBCAT S64...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
