hyrdostatic steering pump filter change
   / hyrdostatic steering pump filter change #1
mad_planter
I was going to change the filter on my 250c this weekend. The filter is inside the pump; You're supposed to be able to drain it in place and then just remove the "cap" to get to the filter. I can't get the cap to come off and I reluctant to pry on it or anything. Is there a trick to removing these besides removing the one long bolt on the end of the cap?
   / hyrdostatic steering pump filter change #2
Don't pry! It's thin metal, it is a snug fit, along with the paint and such keeping it in place. Clean it off good and then get a good grip on it and wiggle it as you pull it to the right. After it starts moving, it will come right off. Be sure to note where the clearance recess is on the back side so you put it back on in the right orientation. From my 345C manual ( same as yours but with a loader)
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2018 KENWORTH T680...
Massey Ferguson 9250 (A52748)
Massey Ferguson...
2017 Rogator RG1300B Dry Fertilizer Applicator (A52748)
2017 Rogator...
2016 FORD F550 CREW CAB SERVICE TRUCK (A52576)
2016 FORD F550...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
Toro Mower (A50324)
Toro Mower (A50324)
