hyraulics question
   / hyraulics question #51
Here's my guess. I don't think it was crud. I think the flow priority valve's spring fatigued.
I suppose that would do it, too. I suspect these flow dividers to be very
reliable, but a separate charge pump on the inlet of the HST to be more
so. My B21 has a small separate trochoid charge pump, which I replaced
due to some internal scoring.
Looking forward to seeing more pix, Matt.
   / hyraulics question #52
Cavitation itself is caused when the pressure on a fluid is low enough to be beneath the vapor pressure of that fluid at that temperature. It is different than foaming and I don't know the relation between the two. If any.
Note that once you have a gas mixed with your hyd fluid due to boiling
(cavitation), compressing the fluid compresses the gas, which adds
a LOT of heat. I don't know how long the boiled fluid stays in the
gaseous state after it passes the inlet (negative pressure) zone.
Foaming, I would expect from air-entrainment that would most likely
occur due to a leak in the suction side of the pump's plumbing. Positive
charge pressure would keep that from happening, of course. It does
happen with implement pumps that get inlet plumbing leaks.
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2022 Wacker Neuson SM100 Mini Skid Steer (A52128)
2022 Wacker Neuson...
2006 MACK GRANITE CV713 DUMP TRUCK (A51406)
2006 MACK GRANITE...
2019 HONDA PIONEER 5 1000 UTV (A50459)
2019 HONDA PIONEER...
2002 NEW HOLLAND 4X4 TN75S TRACTOR (A51243)
2002 NEW HOLLAND...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
