Hyraulics on 3pt not working.. jumping/not lifting on ford 1900. Please Help
   / Hyraulics on 3pt not working.. jumping/not lifting on ford 1900. Please Help #1
dustyfontenot
ford 1900
I just bought a 1981 Ford 1900 tractor. I did a full service. I drained the hydraulic oil where the filter is, the rear diff plug, and the transmission plug, then I cleaned the filter which surprising wasn't that bad. I also did engine oil and fuel filter. Well the first day everything worked fine for 3 hours. But on the second day the hydraulics on the 3pt on rear started lifting slow and started JUMPING when lifting up and will barely lift. I don't see any leaks.
Also the pump sounds like its cavitating. I used a universal hyd oil( Super S).
Any help will be much appreciated!!
   / Hyraulics on 3pt not working.. jumping/not lifting on ford 1900. Please Help #2
Welcome to TBN - Did you re-check hyd levels AFTER you ran it for awhile? Symptoms sound like low level, some machines can get a LOT of air when doing full service, it's always best to "exercise" every circuit several times after filling, then re-check... Steve
Yes, I have checked multiple times. I even loosened the smaller diameter piping on the discharge of the pump (the big bolt on the front right of the tractor) I turned over engine to crank it for like 2 seconds and it sprayed about a 1/2 gallon of hydraulic oil. I then killed it and tighten it back up.
so after that I added more oil to fill it back up.
   / Hyraulics on 3pt not working.. jumping/not lifting on ford 1900. Please Help #5
Sounds like air is trapped in the system some place...
SR
Any tips on bleeding it?
I did some research on the Super S AGRI+PLUS hydraulic oil and it says not recommend for models later than 1974. So I will drain it, and refill with a different oil and maybe something will change.
   / Hyraulics on 3pt not working.. jumping/not lifting on ford 1900. Please Help #7
I had a very similar problem with my Ford 1910. It turned out to be the piston seal on the 3 point hitch lift cylinder. Maybe the oil change is a coincidence. The seal is an easy fix if that turns out to be the problem.
where can I order new seals?
   / Hyraulics on 3pt not working.. jumping/not lifting on ford 1900. Please Help #9
I got mine online from Messicks.
   / Hyraulics on 3pt not working.. jumping/not lifting on ford 1900. Please Help #10
Word of caution... Cheap hydraulic fluid is just that cheap. I bet your fluid is an issue. Buy some not so cheap stuff and refill it. Take the cheap stuff and use it for fire starter.
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2012 WESTERN STAR 4900 SB (A50854)
2012 WESTERN STAR...
2000 John Deere 770CH Articulated Motor Grader (A49461)
2000 John Deere...
2012 GENIE S-60X MANLIFT (A50854)
2012 GENIE S-60X...
CATERPILLAR 304E CR EXCAVATOR (A51242)
CATERPILLAR 304E...
1266 (A50490)
1266 (A50490)
