Hyraulic Fluid of Choice
   / Hyraulic Fluid of Choice #1
TWD
Sierra Nevada Mountains - CA
Kubota M59
I started a thread in the Rural Forum about fluid for my new logsplitter.
$27 for 5G at TSC.
Any reason to spend $$ on synthetic high-end for log splitter? (I run Super UDT/2 in my Kubota, and have a little Super UDT (not 2) left and lots of 2 for my tractor).
Debating if it's at all worth running Super UDT ?
Log splitter will require 15G of fluid, so a lot and adds up :)
Stupid to use snythetic high end fluid in a splitter or ?? What's everyone favorite or stories?!
   / Hyraulic Fluid of Choice #2
Pump, valve, cylinder, tank. It's a simple system, no wet clutch packs or such. Fill it with inexpensive Dino oil meeting the viscosity recommendations and be happy.
   / Hyraulic Fluid of Choice #4
I agree with Rick. Run inexpensive hydraulic oil and you'll be fine. No magic going on in there. :)
   / Hyraulic Fluid of Choice #5
If you built the splitter, use the oil recommended by the pump manufacturer. The mods to my ZTR call for 10W-40 SD or CC oil due to the wheel motors. This is basic diesel motor oil. Which I'm having a hard time finding in 10W-40. :(
Since all you have to worry about is the pump, use the pump specs. Probably any HD hydraulic fluid will perform well.
   / Hyraulic Fluid of Choice #6
About 17 years ago,, I researched oil for a machine I built,,
hydraulic pump, valves, cylinders,,, etc,,,
EVERYTHING I found then recommended having a small percentage of zinc in the oil.
I found the identical oil could be found with,,, and without the zinc.
I ended up finding some Vavoline hydraulic oil that had the specified amount of zinc,,,
I am sure most any good quality hydraulic oil would work for a woodsplitter,,, but,,,
the zinc made me feel good!! :thumbsup:
   / Hyraulic Fluid of Choice #7
Believing in a product has a high value for me.
$87 out the door for 15G at local TSC.
Also snagged some bird feed 35lbs on sale for $7 hard to pass that up for my guineas to snack on :licking: and some starter food for the 13 chickys that just hatched :D :D
   / Hyraulic Fluid of Choice #9
Realize I'm late to the party but I'd recommend any universal tractor oil for a splitter. Reason being that they tend to sit around for long periods of time and UTO is designed to handle the moisture and prevent rust. ISZ
   / Hyraulic Fluid of Choice #10
If the splitter does not have a return filter, put one in! Way more important than what oil is in it. CJ
2022 New Holland Powerstar 110 Tractor with Loader (A51573)
2022 New Holland...
2011 INTERNATIONAL PROSTAR PREMIUM (A52472)
2011 INTERNATIONAL...
Unused Delta Crash...
2009 CATERPILLAR 420E BACKHOE (A51406)
2009 CATERPILLAR...
2014 Ford Taurus SE Sedan (A51694)
2014 Ford Taurus...
2016 VOLVO EC380EL EXCAVATOR (A51246)
2016 VOLVO EC380EL...
