Hyraulic Configuration for 4x20
   / Hyraulic Configuration for 4x20 #1
davey4000
Roxboro, NC
JD 4320, NH TC29D
Is there a web link, or photos showing all three rear remotes and power beyond for the 4x20 series tractors? I'm just interested in seeing what this looks like all decked out.
   / Hyraulic Configuration for 4x20 #2
Davey -- that's a good question -- don't recall seeing a 4000 series 20 with all the hydraulic "bells and whistles" hangin' on the back end!
I recall some pics of a top n tilt configuration that involved 3 SCV functions on the rear of the tractor but don't remember if the PB circuit was there, too?
I'd do a search on the JD owning and operating forum and the hydraulic forum and the projects forum for "top n tilt" and power beyond. See what you come up with...
Welcome to TBN, by the way. Great location to get a tractor "fix" each and every day!
AKfish
Thanks for the welcome and response Fish. Actually, I have been a member since 1999, but after being idle for a while I couldn't remember my old login and password so I created a new one.
I just ordered a 4320 maxed out with hydraulics, FEL, factory TNT and diverter. I guess I'll find out soon enough what it looks like. I have a TC29D and have wanted a bigger tractor for a while now. When I found out that two rear remotes from New Holland was going to cost me $1,500 I decided to upgrade tractors. Now that's logic for you isn't it?
   / Hyraulic Configuration for 4x20 #4
Davey,
I can take some pics when I get home tonight and post them for you. I have an '07 4520 w/ Power Beyond, 3rd svc, and the electric diverter for 2 more svc out the rear.
Thanks rhomium, but don't go to any trouble. I haven't been able to find much on the web or by searching TBN. There are just too many models out there, plus the current configuration JD 4x20's have not been around that long. I hope the 4520 has worked out well for you. I'm looking forward to getting my 4320. Right now I'm trying to figure out what kind of grapple to get. There are certainly plenty of grapple opinions on TBN...that's for sure.
   / Hyraulic Configuration for 4x20 #6
I just took a look in the JD configurator for the 4320. If you go to accessories, the picture for the power beyond kit shows a tractor with PB and with all three rear SCVs.
Hope this helps
   / Hyraulic Configuration for 4x20 #7
This may be a stupid question, but why doesn't John Deere just put 3 SCVs on the back in the first place and not mess with the electric diverter? Is it a cost thing or hydraulic issue?
GreenW,
Thanks for the heads up. I've been all over that configurator and did not see it for some reason.
   / Hyraulic Configuration for 4x20 #9
I have the diverter on my 3520. It is really easy to use since you can only use the front or rear at a time but not both at once. You change quickly with a push of a button. And you are always using the joystick to control the SVC's. It is costly but it is handy. Here is a picture of the back of my 3520 with 3 SVC's. It may look a lot like this.
   / Hyraulic Configuration for 4x20 #10
what mine looks like (4520) with 3rd scv, 4,5 diverter. That will soon change, but for now...
PALLET OF 15-BLACK GROUND PROTECTION MATS. 4FT X 8FT (A53843)
PALLET OF 15-BLACK...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
2024 John Deere 872GP Articulated Motor Grader with GPS Package (A52377)
2024 John Deere...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A53473)
2019 New Holland...
2006 STERLING L7500 DUMP TRUCK (A51406)
2006 STERLING...
