Hypro Pump-Does PTO rotation direction make a difference?
/ Hypro Pump-Does PTO rotation direction make a difference? #1
OkieG
Oklahoma City
Deere 855 (24hp/19@PTO)
For 5 years I've used a Hypro 6500C model PTO pump with a 3PH sprayer. There are arrows cast on the housing next to the IN and OUT ports indicating the direction for PTO shaft rotation. The direction of the arrows match the rotation of my tractor's PTO...clockwise as you look at the shaft from the back of the tractor.
I've just "upgraded" to an XL model of the 6500. I just noticed the arrows show for rotation to be counterclockwise, which my tractor can't do. Does anybody know if it matters which way the PTO rotates with respect to pump function? Do any small tractors that would use such a pump have counterclockwise rotation of the PTO? I thought all small tractors' PTOs ran clockwise. I'm confused. Thanks for any help.
OkieG
/ Hypro Pump-Does PTO rotation direction make a difference? #2
According to Hypro's website, the 6500 series models are standard counterclockwise rotation, but clockwise is available. If you purchased from a dealer, I would take it back and ask them to order the correct rotation. While you may possibly make it work by hooking it up backward, IMO it would not work as well, if at all. Here is a link to the 6500 series:
Spray - Series 6500 - Features
/ Hypro Pump-Does PTO rotation direction make a difference? #3
If you have the instructions and a press you should be able to press the rotor out of the bearings and reverse the rotor so it changes rotation.
David
/ Hypro Pump-Does PTO rotation direction make a difference? #4
The rotor within the pump is the determining factor for rotation. If it is possible to reverse it your problems are solved. I believe the pump will work rotating the wrong direction but it will never reach rated output.
Brake Drums (A62613)
2023 TEXLINE BOBCAT HAULER (A65643)
2023 TEXLINE...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
2016 Ford Escape SUV (A64557)
2016 Ford Escape...
Landhonor Mini Skid Steer Rock Grapple (A62679)
Landhonor Mini...
2019 John Deere 4044M (A62177)
2019 John Deere...
