Hypothetical question on pressure bypass
   / Hypothetical question on pressure bypass #1
jmc
Elite Member
SW Indiana
Ford 1920 4x4 (traded in on Kubota). Case 480F TLB w/4 in 1 bucket, 4x4. Gehl CTL60 tracked loader, Kubota L4330 GST
Hello All,
Let's say I have a hydraulic top link on a 3 PH and I'm using a back blade (but not adjusting the top link) when I hit an obstruction. If the resulting pressure in the top link cylinder from this external load exceeds the bypass pressure setting, does the bypass valve open?
Thanks.
John
   / Hypothetical question on pressure bypass #2
Hello All,
Thanks.
John
To protect from that external "shock", you need a "shock" Releif Valve, RV ,between the Control Valve, CV, and the cylinder (aka port releif valve).....then, yes, the RV will open.
This picture shows a double crossover RV....
   / Hypothetical question on pressure bypass #3
Hello All,
Thanks.
John
The short answer is NO. The reason is because the work ports of the valve are blocked when the valve is in neutral, and the PRV is on the IN port of the valve.
   / Hypothetical question on pressure bypass #4
Kennyd!! I hope I did not express my self that bad so I got
of course the pump protecting PRV can never protect from external force shocks......;)
   / Hypothetical question on pressure bypass #5
Kennedy!! I hope I did not express my self that bad so I got
I was just saying it in a different way, that's all;):D
   / Hypothetical question on pressure bypass #7
Some valves also have work port relief in addition to PRV.
Thanks, everyone, for the replies. I should have known it would't be simple.
John
2007 Toyota Tundra 4WD Pickup Truck (A53117)
2007 Toyota Tundra...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2017 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2017 KENWORTH T680...
2025 Big Tex 14GN-40D5A 35ft 6 Ton Gooseneck Flatbed Trailer (A51692)
2025 Big Tex...
