Hydrualic Toplink Holder
   / Hydrualic Toplink Holder #1
Zebrafive
Super Member
South West MI
John Deere 2030, John Deere 6415
I bought my toplink from Fite Right Hydraulics. At 25 lbs a bungie cord would not cut it for a holder. So I made my own. More bought it than made it. The handle/holder is the same as used on my original toplink. I bought it from the dealer along with the two spring pins that hold it in place. The clamp is from ebay, a T-Bolt clamp, said to be stronger than hose clamps. First one I bought was too big. They sized it for silicone hose and it was 1/2" bigger than the hose size. I bought a 3 1/2" and it was more like 4". Second clamp (3") was just right. Also from eBay was a scrap of aluminum.
Since I do not have a machine shop I choose aluminum. Sawed with a hacksaw and drilled on Harbor Freight drill press. I experimented with a scrap of wood to get the holes right, I wanted a little preload so it would stay tight to the link when not in use. So the holes are not the same as on my top link.
The bottom of the aluminim block is filed to match the cylinder and ends cut at a 45. Then a slot cut for the clamp. I put the slot towards the tractor side. I had considered slotting both ends and using two clamps. I think one is enough.
Pictures show the Implement end to the left. Asembled, but not mounted, notice the preload to keep the handle tight to the cylinder. On the original toplink it was used to lock the setting of the toplink by engaging the implement end. It pivoted forward to hook on tractor bracket when not in use.
It mounted right over Fite Right Hydraulic's sticker. (Sorry Brian. if you send me a couple more stickers I'll add them below so they wlll show)
Also note the custom laser engraving on the clamp. I'll post more pictures when I mount it on my tractor.
   / Hydrualic Toplink Holder #2
Very nice.. And very impressive work without a machine shop at your disposal! Great job!!
   / Hydrualic Toplink Holder #3
Very nice work, always nice when the OEM style link retainer is used. :thumbsup: Just takes a little work, but well worth it in the end. :cool:
   / Hydrualic Toplink Holder #4
Nice job on that detail. Most folks don't know that it's not the tools that makes the toolmaker, it's the tool in his head.
   / Hydrualic Toplink Holder #5
You need to sell that to Deere because their design for the same application on a 3520 is a joke....
I have not resolved it with the dealer on my new tractor, but they are aware of it.
   / Hydrualic Toplink Holder #6
Impressive hand work on that block of aluminum.
How about a picture of the setup on the tractor?
   / Hydrualic Toplink Holder #7
Really impressive work indeed! I like the finishing touches on the band too:)
   / Hydrualic Toplink Holder #8
Very nice! Will definitely be doing something similar to my Fit Rite top link.
On another note, with the scv in float, are you able to compress or extend the top link cylinder to fit the implement you're adding or removing? Mine is real tight and I typically have to jump in and out of the cap to adjust in or out to connect implement, or to get is loose to where I can remove the top pin to disconnect an implement.
   / Hydrualic Toplink Holder #9
You're moving a lot of fluid, even with it in float it is a very difficult thing to do. Do you have your flow restrictor set? :eek: I doubt very many people could even move the ram when there is a flow restrictor involved.;)
   / Hydrualic Toplink Holder #10
Yes, I do have the flow restrictor in-line. I was starting to worry if I was getting real weak or something. :)
Perhaps one day I'll wire up the right fender switch that is currently for raising/lowering the EH, to instead extend/retract the top link cylinder.
UNUSED RAYTREE RMT48-48" TRENCHER (A51248)
UNUSED RAYTREE...
12' CONTAINER (A51248)
2018 MDB T5E MDB DISC MOWER (A51247)
2018 MDB T5E MDB...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
