Hydrualic quick connects the same?
   / Hydrualic quick connects the same? #1
300UGUY
Super Member
Howell, Michigan
Kubota L3400, Farmall H
I noticed a ad for a pressure gage set up for a hydrualic connector, sold for bx25's. I have a L3400, will the gage work on my connectors?
   / Hydrualic quick connects the same? #2
You can do it much cheaper than that kit!! ~$15 for the coupler and ~$5-10 for the gauge.
As to what coupler you need, I'm pretty sure the BX25 is a Parker 60 series. 1/4" threads. Model H2-62. (I'm positive its a 60 and 99% sure its 1/4")
Id imagine the L has a larger coupler, in that case the BX coupler in the set wouldnt work anyways.
Best thing you should do is go look at an existing coupler on your tractor, it should be stamped with what size it is. Then get the same and make your own gauge setup.
   / Hydrualic quick connects the same? #3
Print this PDF out to check sizes.
  • sizechart.pdf
2018 Ford Transit 250 Cargo Van (A48081)
2018 Ford Transit...
66in Light Material Bucket Skid Steer Connection (A51039)
66in Light...
Iron Cabinet (A50860)
2008 CAT 287C (A50854)
ATV Racks (A50860)
ATV Racks (A50860)
Super Material Lift MH1000 (A51039)
Super Material...
