Hydrualic 3pt. tilt?
   / Hydrualic 3pt. tilt? #1
DirtyDusty
North Louisiana
New Holland TN75
I was wanting to put a hyd. cylinder where my adj. link is on my TN75. Not the top link just the side. Does anyone know what size cylinder I need? Maybe a link to one for sale?
   / Hydrualic 3pt. tilt? #2
I have an 3" diameter x 8" stroke on my 7520 Mahindra. Your TN75 should be about the same size machine. CCM might be able to help you out or just do a search on Google for one. eBay maybe? I would think that either an 8" or 6" stroke is what would work best.
Good luck
   / Hydrualic 3pt. tilt? #3
Brian has a good sized cylinder on his Mahindra and I also used big ones on mine. My tractor isn't quite as big as either of yours, but I decided to use 3-1/2" diameter cylinders with 1-3/4" shafts. I had bent one of the stock turnbuckles which was 1-1/8" diameter. So I opted for larger rods. I bought these from Surplus Center who advertises on this board.
I also put them on both sides.
Here is a link to their installation if it will help you.
Adding Hydraulic Side Links
REIST R25PSS LOT NUMBER 231 (A53084)
REIST R25PSS LOT...
2017 Claas Jaguar 860 Forage Harvester (A53472)
2017 Claas Jaguar...
2012 Altec WC126A Chipper S/A Trailer (A51691)
2012 Altec WC126A...
2018 VOLVO VNL DAY CAB (A52576)
2018 VOLVO VNL DAY...
Power Liner 4000 Paint Striper  (A52384)
Power Liner 4000...
2008 OVERLAND TANK KILL TRAILER (A52472)
2008 OVERLAND TANK...
