Hydrostatic vs Non
   / Hydrostatic vs Non #1
hiker88
Bronze Member
belgrade, maine
none
Are there any advantages to not getting a tractor with a hydrostatic transmission? Are non-hydro units cheaper or more durable? I know someone who is really down on hydrostatic transmissions and just wondering if there is any truth at all to it.
I'll be using my tractor for woods work and snow removal. so I foresee a lot of back and forth and FEL work. I thought from my research here a hydro would be the way to go, but would just like to confirm that.
Also is "shuttle shift" the term for something that is not hydrostatic, or is that something else entirely?
Thank you,
   / Hydrostatic vs Non #2
I don't like hydro transmissions at all!
But that doesn't mean they are bad. Both types are good!
"shuttle shift" is forward/reverse without clutching, otherwise a gear drive and a good choice.
Buy what ya like.
   / Hydrostatic vs Non #3
I have a geared tranny in my Deere 5045D, and I love it. I do a lot of loader work with it moving snow, and it's never been a problem for me. The low/reverse shifter acts pretty similar to a shuttle shift, besides having to use a clutch. I cannot comment much on a hydro trans, because all I've ever used was geared, but they're definitely more expensive, and IMO, there's more to go wrong. If I were you, I would go to the dealers and have them let you test drive both, that way you can get a feel for it yourself...a little seat time in both will be worth a million different opinions about it on here. Good Luck!
Sent from my LGL35G using TractorByNet
   / Hydrostatic vs Non #4
Quite a few threads on this, here is the latest:
http://www.tractorbynet.com/forums/...891-dt-transmission-vs-hst-transmissions.html
There are those who refer gear and those who prefer HST. I use both and both have their place, for frequent changes in direction, I prefer HST.
Shuttle shift will be a geared tractor, you have several types, unsynchronized in which you must come to a full stop before engaging the lever to go from forward to reverse; synchronized in which you can change from forward to reverse without coming to a full stop though you will need to really be going slow, and hydraulic shuttle shift in which your forward/reverse shift includes a hydraulic clutch, so you don't need to use the foot clutch for direction changes. With shuttle shift, you will have the same number of speeds forward as reverse. Maybe someone else can give a more in depth or easier to understand definition.
   / Hydrostatic vs Non #5
if your going tobe doing alot of loader work then hst is the way to go.a gear tractor will eat your clutch leg up.thats why alot of farmers an cattlemen are crippled up in their old age is because they rode the clutch for years.
   / Hydrostatic vs Non #6
Never had hst on anything bigger than a riding mower. But from what I heard, if you are going to be doing heavy plowing and the like, a geared tractor has more power at the wheels. If a great deal came along on a hst, it wouldn't keep me from owning one, but if I was out looking, I would go for the geared. Less money, and less to go wrong.
I've only moved snow with a shovel {during my Navy days}, but I'm guess it is easier on a tractor than dirt. For what you need a hst would do the job, just at a slightly higher price.
   / Hydrostatic vs Non #7
For tractors with 20-hp to 50-hp with FEL, HST is the preferred option. On slopes, pulling an implement, you do not want even a second with the tractor "out-of-gear". HST is a little more expensive than other transmission options.
For ag-tractors, 70-hp+, where most tractor work is pulling straight forward the length of a field, many prefer some form of gear transmission. Gear transmissions are slightly more fuel efficient. For full-time farmers 5%-6% fuel savings can be a lot of money during a year.
Shuttle shift is one form of geared transmission.
   / Hydrostatic vs Non #8
I have a gear tractor with a shuttle for forward and reverse and it requires clutching. I can shuttle while rolling. Except for "creep" (you can get creeper in some gear tractors) with 12 forward and reverse gears I can find a combination of speed and power for any given task it seems. I don't mind clutching, just seems natural to me. Put me on an HST and I'd probably run down something. Took a joy ride down a small slope when my hst lawnmower was first new. :laughing:
I'm not "down" on HST, but I don't think you should ignore the higher cost new, higher maintenance costs ongoing, more to break or go wrong, and hydraulic whine that is part of owning an HST. HST is more popular by far in CUTS than gear, so higher resale if that matters.
Some cab model CUTS are only available in HST.
Well, I'll just come out and say it - it's my dad that is so anti HST and it's one of those things I'll never stop hearing about. Might not seem like much, but some of you may understand.
As a kid I bush hogged 60 acres of his fields every other year with an old ford geared tractor. I can remember some situations where the ground was rough and I had to lower the rpms to stop from abusing the tractor, but then you would lose PTO RPMs as well.
I have a gravel driveway, so I need to be able to go pretty slow sometimes, yet have enough power to move the snow.
Thoughts?
   / Hydrostatic vs Non #10
On today's new tractors wheel RPM is independent of PTO RPM.
Therefore you can be at full stop or drive slow or fast while PTO maintains 540 RPM.
Tractor HST transmissions have improved as much as automobile "automatic" transmissions over the last 20 years.
We see "Dad dislikes" HST, FDR, taxes, etc. all the time on this site.
When "Wife dislikes" you got to pay attention......
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A52748)
2023 New Holland...
Kinze (Delgelman) MT 201 High Speed Disc (A52349)
Kinze (Delgelman)...
2015 Chevrolet Express 4500 Shuttle Bus (A50323)
2015 Chevrolet...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2015 Ram 5500 Versalift SST-40NE 40ft Sign Bucket Truck (A50323)
2015 Ram 5500...
2016 CHEVROLET SIVERADO 4X4 PICKUP (A52577)
2016 CHEVROLET...
