Hermio
- Joined
- Jul 28, 2014
- Messages
- 355
- Location
- Clarksville, OH
- Tractor
- Mahindra 5035 HST w/FEL and 4-way bucket; Ford 4110
Many forums have discussed the transmissions available: gear, shuttle or hydrostatic. One point that I have not seen mentioned is safety. With any gear drive tractor, if you get into a situation where the tractor is apt to flip over or roll over, you must rapidly find the clutch and disengage it before the rollover occurs. The whole process may take less than a second, and you have to find the clutch while you are in the process of being tossed about on the seat, or maybe even tossed out if you are not wearing a seatbelt. With a hydrostatic drive, all you have to do is stop pushing down on the HST pedal, and it will stop almost instantly. If you lift or drag heavy loads on slopes or in woods, this can save your life. Unless all you do is flat work with no heavy pulling loads, you should seriously consider an HST model. By the way, the lower theoretical efficiency of an HST drive is often made up for in mowing or similar applications by being able to speed up or slow down as the load changes, whereas with gear drive tractors, one tends to stay in a gear selected to let the tractor do the job in the toughest areas, and then not work as fast or as hard in the easy areas.
