Hydrostatic transmission
   / Hydrostatic transmission #1
rc44001940
lewiston, Idaho
mahindra/ 2615
I have a 2615 Mahindra tractor. ( Hydrostatic Transmission & Hydrostatic filter) Can i use transmission & hydraulic oil for the transmission or do i have to use hydrostatic transmission oil. Which i heard is quite expensive.
Thank you; if you care to respond to rc44001940@yahoo.com; as i need to now asap.
   / Hydrostatic transmission #2
You need to use the proper fluid. You know that..Most modern CUTS have wet brakes, and you must use a fluid designed for wet brakes. Automatic transmission fluids and hydraulic fluids not designed for wet brakes will cause problems. Hydrostatic transmissions have very precise tolerances and need the proper fluids to operate well. I cannot imagine trying to save a few dollars on fluid to spend hundreds or thousands on repairs..
Ford Tractor (A50120)
2019 Generac Mobile MLT4200 20KW Towable Light Tower (A52377)
2019 Generac...
2006 Kobelco SK210LC Hydraulic Excavator (A52377)
2006 Kobelco...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
Utility Trailer (A52377)
Utility Trailer...
