Hydrostatic transmission
   / Hydrostatic transmission #1
rc44001940
lewiston, Idaho
mahindra/ 2615
I have a 2615 Mahindra tractor. ( Hydrostatic Transmission & Hydrostatic filter) Can i use transmission & hydraulic oil for the transmission or do i have to use hydrostatic transmission oil. Which i heard is quite expensive.
Thank you; if you care to respond to rc44001940@yahoo.com; as i need to now asap.
   / Hydrostatic transmission #2
You need to use the proper fluid. You know that..Most modern CUTS have wet brakes, and you must use a fluid designed for wet brakes. Automatic transmission fluids and hydraulic fluids not designed for wet brakes will cause problems. Hydrostatic transmissions have very precise tolerances and need the proper fluids to operate well. I cannot imagine trying to save a few dollars on fluid to spend hundreds or thousands on repairs..
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2018 FREIGHTLINER...
2017 FORD F150 REG CAB LONG BED 4X4 (A54313)
2017 FORD F150 REG...
2008 KOMATSU PC200LC-8 EXCAVATOR (A52706)
2008 KOMATSU...
1265 (A50490)
1265 (A50490)
Galvanized Livestock Gates - (6x Total Gates) (A55218)
Galvanized...
2020 John Deere XUV 835M Gator 4x4 Utility Cart (A51691)
2020 John Deere...
