HYDROSTATIC TRANS
/ HYDROSTATIC TRANS #1
STTAS
ILLINOIS
1120 CASE / B2100 KUBOTA
I HAVE A CASE 1120 WITH HYDROSTATIC TRANS, WHEN RELEASING THE PEDAL THE TRACTOR STILL CREEPS, ANY IDEAS ON HOW TO FIX THIS. DEALER WANTS 100.00 TO CHECK IT OUT. STEVE
/ HYDROSTATIC TRANS #2
Mine does it too. Creeps forward. I can stop it with a stout parking brake setting, clutching, or taking it out of gear. Lubricating the pedal pivot helps to bring the pedal back to center/neutral better.
/ HYDROSTATIC TRANS #3
Do not know if this will apply to your tractor,but I had a TC 40 D that had the duel pedal set up and there were adjustment screws/stops that could be adjusted to prevent creep in forward or reverse.The bolts were located on the on the pedal linkage so when you let off the pedal it would return to a neutral posistion. I found out about these after a large stick made an adjustment of it's own. Hope this helps?
/ HYDROSTATIC TRANS #4
Depending on my direction when my Bota does this I just push the pedal in the other direction and it stops. Its like the fluids still flowing a bit of residual. Its not all the time and it stops as soon as i do this. If yours is diffrent I Don't Know /forums/images/graemlins/smile.gif
/ HYDROSTATIC TRANS #5
There may be an adjustment that helps center the pedal.
My tractor has a wobble plate screw for this.
Egon
/ HYDROSTATIC TRANS
theres a type of hydrolic spring i have been playing with the adjustment and it seemed to help
/ HYDROSTATIC TRANS #7
My Kubota B7510HST has a grease zerk on the go pedal mechanism. Supposed to be lubed every 50 hours. Since the pedal linkage is hanging out in the breeze, it's easy to get dirt/debris in the workings. I'd check this before trying to make any adjustments.
YALE VERACITOR 50VX STRAIGHT MAST FORKLIFT (A63276)
YALE VERACITOR...
John Deere 1025R Tractor (A64047)
John Deere 1025R...
UNUSED RAYTREE RABC44 - 44" ARTICULATING CUTTER (A62131)
UNUSED RAYTREE...
2018 Komatsu D61PX Crawler Tractor Dozer (A59228)
2018 Komatsu D61PX...
John Deere 5101E Tractor w/ John Deere Loader (A64047)
John Deere 5101E...
2016 Ford F-550 4x4 Mason Dump Truck (A61568)
2016 Ford F-550...
