Hydrostatic tranny?
   / Hydrostatic tranny? #11
My old WH Charger 12 called for Automatic Transmission Fluid (Type F) where as my Troy-Bilt Hydro calls for 20 wt oil.
   / Hydrostatic tranny? #12
My old Case 12HP tractor called for either 10w30 or 10w40 in the what they called the Hydraulic drive. I don't think it was officially a Hydrostatic drive. It had a hydraulic pump driving a hydraulic motor which drove a transaxle. I really abused that machine for 20 years or so. My dad is still using it.
   / Hydrostatic tranny? #13
Just an FYI, ATF is a hydraulic oil. It is lighter weight (thinner) than common hydraulic fluids, but otherwise the same. It is comparable to MIL-H-5606 hydraulic oil, which is equally thin. That oil is the standard for military jet hydraulic systems. The low viscosity is preferred as it thickens up at the low ambient temps that aircraft normally experience at altitude. For industrial and mobile operation, with oil operating temperatures of 110-120 F, 5606 get a bit too thin for some equipment, and is often not liked by many engineers in the industry.
One other point I unearthed (talking to our fluid expert) is that the biggest negative to motor oil in hydraulic systems is the detergent additives, which can cause foaming and oil breakdown in high pressure, high fluid velocity systems. A non-detergent oil is much favored if it is used for hydraulics. But again, if the tranny is operating conservatively, by hydraulic standards, these issues may be minor.
paul
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
HAULMARK ENCLOSED RACE CONVERSION TRL (A52708)
HAULMARK ENCLOSED...
BEFCO DISC MOWER (A52708)
BEFCO DISC MOWER...
New/Unused Mini Crawler Dump (A57453)
New/Unused Mini...
Trimble Surveying Equipment Mounting Posts (A55973)
Trimble Surveying...
(2) UNUSED 320/85R24 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
