Hydrostatic steering cylinder leaking
/ Hydrostatic steering cylinder leaking #1
KTurner
I have a 1992 3230 with a leaking steering cylinder, which I've already removed from the tractor. The cylinder is e7nn3A540CB and it looks like the seal kit is fp526. I've never replaced seals in a hydraulic cylinder before, but am considering giving it a go. This cylinder appears 'backwards' compared to the information I've seen on rebuilding cylinders in that the rod end of the cylinder is fixed and the base end is where you open it up. The kit also has a couple 'large' pieces that could be bushing, spacer, install tool, etc. The kit doesn't appear to come with any instructions. Anyone know where I can find some info on rebuilding this, or a similar type of, cylinder?
Thanks
Keith
(2) Wheel Weights (A64127)
(2) Wheel Weights...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
Lonestar Panel 24ft. Free Standing Panel with 7ft. Gate (A65640)
Lonestar Panel...
DRILL CABINET SKID (A60736)
DRILL CABINET SKID...
2014 Bobcat T870 (A64126)
2014 Bobcat T870...
Vermeer 604 XL-Series (A62177)
Vermeer 604...
