Hydrostatic Replacement
/ Hydrostatic Replacement #1
Tractor Tom
New Brunswick, Canada
Kioti CK35 H
My CK35HST with 80hr's on has to have a complete new Hydrostatic unit installed. Last fall I posted that at slow speeds the tractor would pulsate in forward or reverse, regardless of RMP. This spring is got to be so bad I called the dealer again to have it looked at again. Dealer says they have had a few tractors that will pulsate some when new, but usually stops after a couple of hr's, but nothing to the degree that mine pulsates. Kioti has agreed to replace the complete Hydrostatic unit. Luckily all is covered under warranty....except my time without a tractor.
Just wondering if anyone else has had a pulsation issue with there HST Kioti??
/ Hydrostatic Replacement #2
My white kioti will pulsate a little at low rpms. I be leave we have the same hydro unit.
/ Hydrostatic Replacement #3
On my first Kioti tractor (CK30HST) I had no pulsation at all. On my new tractor (CK35HST) I did have a very faint pulsation in reverse when I first got it. Now it seems to have worked itself out of it as you said. Then again I only have 22 hours on it. :thumbsup:
/ Hydrostatic Replacement #4
Nothing like that for me after 150 hrs.
John Deere Lift Arms (A65640)
John Deere Lift...
2002 Massey Ferguson 1233 Tractor (A66285)
2002 Massey...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
Pallet Racking (A65640)
Pallet Racking...
Used 20' Container (A62679)
Used 20' Container...
2001 MACK RD688S ROLL OFF TRUCK (A65643)
2001 MACK RD688S...
