Hydrostatic How does it work mower
   / Hydrostatic How does it work mower #1
coffeeman
Platinum Member
If the mower doesn't pull forewarrd is there any things that might be simple fix with hydrostatic. Trans? The mower is one of the K Mart kind like MTD or similar.
Cheers coffeeman
   / Hydrostatic How does it work mower #3
Sometimes it is just a little wire spring type device that you pull out and lock so you can free roll them. Look for one on each trans axle at the rear of the mower but I think some of the tractor type may only have one valve to open as opposed to ZTR mowers that have one for each wheel. Your operators manual should depict this if you have it. If not it may be online.
   / Hydrostatic How does it work mower #4
Was it acting strange previous to not moving? Check to see if any of the bolts attaching the linkage to the foot pedal or control lever came loose also if belt is turning the hydro.
It's my daughters mower. I do think it was acting funny. I'll ask her tomorrow. I'll probably look at it this week too.
Cheers....Coffeeman
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
2012 CHANDLER 130 BBL STEEL VACUUM TRAILER (A53843)
2012 CHANDLER 130...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
1994 Fontaine 48 ft. T/A Float Trailer (A53117)
1994 Fontaine 48...
LOT LOCATIONS (A54313)
Econoline RA-48X24 Sand Blaster (A53117)
Econoline RA-48X24...
