Hydrostatic Fluid Question
   / Hydrostatic Fluid Question #1
NCMau
NC
MF 202/Ford 8N
My JD 425 tractor/lawnmower has a hydrostatic transmission oil leak. It is not a big leak, but it is big enough to replace a quart every 2 or three months. I know the proper thing to do is to start dismantling and find the leak, and I will do so in the near future, but right now I just don't have the time.
The recommended fluid is JDM J20D/C. Since this oil is pretty expensive, I was wondering if there is a cheaper suitable replacement oil available until I get this problem fixed. The manual specifically states NOT to use engine oil or type "F" ATF.
   / Hydrostatic Fluid Question #2
I also have a 425 and use amsoil fluid, no issues; for the last 14 years.
Thanks for sharing the info. What type of Amsoil are you using? A quick search revealed several types.
   / Hydrostatic Fluid Question #4
amsoil 'anything' is likely even more expensive than the dealer oil.
see if a generic utf made by warren or similar will meet the specs.. IE.. walmart ort tsc lubes..
soundguy
2017 Chevrolet Colorado Crew Cab Pickup Truck (A53422)
2017 Chevrolet...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2018 KENWORTH T800 DAYCAB (A53843)
2018 KENWORTH T800...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2007 DRAGON 150...
