Cephas in your other thread you posted today you say your angle blade only turns in one direction. Assuming it's the same piece of equipment and blade only angles one way and tractor only moved one direction? Seems like an issue with hydraulic flow...is there more to the story? Like everything was normal until I hooked up this blade? Did both these things start at the same time?
