Hydrostatic drive not working properly
/ Hydrostatic drive not working properly #1
Stirdy
wayland, mi
husqvarna 24hp 48"
I pulled my Simplicity Legacy out of the barn yesterday morning just fine. A few hours later I went to use it, started it, let the parking brake off, pressed down on the forward pedal and it moved very slow for a few feet then stopped. I pressed down on the reverse and it moved backwards slowly for much further then stopped.
I added a small amount of hydro fluid to the transmission and started it up and it reacted the same. I kept on running it back and forth, then the reverse stuck on full speed. I rode it around d the yard and had to turn the key off to stop it. After messing with it some more it then got stuck in the forward position.
After shutting it down again it is now doing the same as before, slowly moving in either direction then stopping.
Any suggestions???
This is not a good time for it to be broke down, as I am using the loader attachment to dig a pool.....
/ Hydrostatic drive not working properly #2
Sounds like the linkage came apart.
