hydrostatic drive belt problem
/ hydrostatic drive belt problem #1
Eric_Phillips
Platinum Member
Rochester, NY
FarmTrac 270DTC
I have a Ferris ProCut 32 that has hydrostatic drive. There is a belt that comes off a pulley on the engine shaft, around the pulley on the hydraulic pump and it tensioned with a spring tensioned idler pulley. My research found the belt is 5/8" x 40". It took awhile but I found one. The reason for replacing it is the old one shredded. After I replaced it the mower moved very slow and would barely make it up a slight slope. Usually when done mowing I lower the throttle on the mower and the hydraulic pump or the drive motors groan a little when moving. With this new belt and the engine running full throttle I was getting a groan. I do not hear any slipping of the belt. I measured the belt I took off and it was only 1/2". The back side of the 5/8" belt is level with the pulley flange. the springs on the idler pulley are not pulled super tight, they look similar to how the old belt was. Any ideas what might be wrong?
/ hydrostatic drive belt problem #2
Can you physically see the all the pulleys turning while under load? Going from 1/2” to 5/8” I would question if V of the belt is making good contact with V of pulleys and just slipping from minimal surface contact.
/ hydrostatic drive belt problem #3
I realize that V belts drive off the side but saying that, I think the belt should be deeper in the groove, I've not seen one that rides that high. Wrong profile maybe that's bottoming out?..........Mike
/ hydrostatic drive belt problem #4
Maybe you have a B belt where you should have an A belt.
Thanks for the information. Sounds like maybe I got incorrect information and it does need a 1/2" belt. The belt is a real pain to change since it is tucked up underneath the mower.
/ hydrostatic drive belt problem #6
My scag tiger cat has recently started to eat them once a month. Can change it out in 10min. Now I had a toro z master a long time ago that would go thru them every 2 months but it took a long time to change that one. Had to remove clutch brackets on it. Got rid of it
New/Unused Wolverine 3 Point Hitch Coupler (A65583)
New/Unused...
New/Unused CFG Industrial H12R Mini Excavator (A65583)
New/Unused CFG...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2011 CASCADIA 6X4 T/A DUMP TRUCK (A59914)
2011 CASCADIA 6X4...
2006 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A64194)
2006 Chevrolet...
