hydrostat
   / hydrostat #1
greenB
I just pick up a JD4200 that does not run. My question is , how do you make it free wheel(roll)?
   / hydrostat #2
Welcome to TBN:D
On the left side, the range lever will have a Neutral position in addition to the A,B, and C ranges. Neutral is between A and B.
Here is a link to the 4200 Operators Manual
   / hydrostat
Thanks Kennyd. I might be able to get it on the trailer and home.
   / hydrostat #4
Coupla winters back my fuel solenoid shorted out killing the engine on my JD4300. Figured I'd get my SIL to tow it back up my driveway to the garage where I could work on it. Got the rope on it and then found out that the hydraulic power steering is just that. When the hydraulic pump ain't working you ain't got NO steering, unlike a car where you still have mechanical linkage. Luckily you still have steering brakes however....
2017 Dodge Charger (A53424)
2017 Dodge Charger...
2013 MACK CXU613 (A53843)
2013 MACK CXU613...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2018 WACKER NEUSON RTSC3 ROLLER (A54607)
2018 WACKER NEUSON...
