Hydrostat pedal on L47
   / Hydrostat pedal on L47 #1
Notforhire
Southwestern Virginia
Kubota L47TLB
I just bought a L47TL and so far I'm pretty happy with my purchase.
On thing that I wish Kubota did differently was the design and/or location of the hydrostatic control pedal.
I have arthritis in my right hip and I find it difficult to operate the pedal for any length of time. I presume that Kubota located it that far to the right in order to make room for the brake pedals in an earlier design.
Since the brakes are now on the left side, the hydro pedal could be moved or at least switch the wing to the left instead of the right.
Until they do, I made a modification that just clamps to the existing pedal. There is a set screw located on the bottom side, that locks everything in place.
I may install a pad so there is a larger surface to put my foot against.
If anyone has built something similar, or has a better solution, I would appreciate hearing from you.
   / Hydrostat pedal on L47 #2
Great modification and I will have to check ours! I hardly ever use the rocker because it is so easy to put the toes under the petal and lift for reverse. I typically only go to the rear of the treadle petal for long periods of backing up. I like the looks of yours as that would require less movement yet!
   / Hydrostat pedal on L47 #3
357CBB58-3128-4DC4-BF5C-B60C387FF44D.jpeg12AA597F-7ED2-47BF-8E35-E31FB479AF18.jpeg2E769E36-1463-42E2-88A4-E5F10B7F1000.jpeg
I hate the kubota pedal. Mines bolted on.
   / Hydrostat pedal on L47 #4
Great modifications to a very stupid archaic design. Now someone who has modified the big banana pedal has to chime in. I will never buy Kubota as long as they have that kind of pedal. I made the mistake of buying a new Holland with a treddle pedal and can't weight to get rid of it . Love the tractor hate the pedal.:drink:
After "test driving" it at the dealer I disliked the treadle, but since no one else makes a machine to compete with the L47 I figure I'd adjust. After running it for several hours, my bad right leg began to really bother me. The next day I could hardly walk.
The only reason I didn't drill and bolt something on was I was afraid that I might have to return the tractor to the dealer and didn't want a permanent modification.
Now that I think I'm on the right track, I'm feeling better about the machine. I appreciate your comments, ideas and photos.
My original thought was to remove the pedal and redesign something better to go in it's place. Now I'm not so sure if that necessary. Maybe a little wider "wing" like Hersheyfarm has will do the trick.
The design group at Kubota must have run out of funds when they got to designing the HST control. In todays world of ergonomic designs, does anyone find this thing comfortable to operate?
Maybe if I get a hip replacement I could get the Docs to install an extra joint above my ankle. Yeah, that might work.:confused2:
   / Hydrostat pedal on L47 #6
I have no issues. I dont use it like a rocker at all. Forward my foot is to the right top side. Reverse I pick my foot up and pull it back and left to press reverse. Almost feels like a gas and brake pedal movement on the truck.
Are you trying to use it as a rocker?
If the "wing" was on the left side instead of the right side of the rocker, would you find it easier to reach?
I operated mine just as you describe, which would have been fine if the petal location wasn't so far to the right.
   / Hydrostat pedal on L47 #9
Thats just such an awkward position to me. Wing needs to be on left side.
   / Hydrostat pedal on L47 #10
Great idea!
I will modify mine.
Maybe use carriage bolt heads instead?
Carriage bolts would be good if you could drill a square hole so you could snug them up good.
Honda ES 6500 Generator (A55973)
Honda ES 6500...
Bucket (A55973)
Bucket (A55973)
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A58018)
2020 FREIGHTLINER...
2016 Ford F-350 (A56858)
2016 Ford F-350...
COPPER POT & COIL (A58374)
COPPER POT & COIL...
2015 INTERNATIONAL DURASTAR 4300 (A58214)
2015 INTERNATIONAL...
