Hydrolic Leak MT372D
/ Hydrolic Leak MT372D #1
Solideal
After changing out all the rubber lines on my MT372D I sprung a leak on a steel one. The steel line coming from the power block{left side of seat}, to front of the oil filter housing. At that juncture, which appears to be a banjo fitting, is were the leak occured. It's hard to tell if I have a cracked housing or o-ring failed. Worst case scenario, does anyone know where I can find a new or salvage part?
/ Hydrolic Leak MT372D #2
That leak point is common on the Mits clones. (Cub, Mahindra) Usually just a matter of snugging it down a bit. Might well be a stat-seal (rubber covered washer) under the banjo? Probably get that at any decent equipment dealer. Hope it is nothing worse.
/ Hydrolic Leak MT372D #3
If you need a line or parts, contact me thru email or 1-800-609-5110. Bill
