Hydrolic Leak MT372D
   / Hydrolic Leak MT372D #1
Solideal
After changing out all the rubber lines on my MT372D I sprung a leak on a steel one. The steel line coming from the power block{left side of seat}, to front of the oil filter housing. At that juncture, which appears to be a banjo fitting, is were the leak occured. It's hard to tell if I have a cracked housing or o-ring failed. Worst case scenario, does anyone know where I can find a new or salvage part?
   / Hydrolic Leak MT372D #2
That leak point is common on the Mits clones. (Cub, Mahindra) Usually just a matter of snugging it down a bit. Might well be a stat-seal (rubber covered washer) under the banjo? Probably get that at any decent equipment dealer. Hope it is nothing worse.
   / Hydrolic Leak MT372D #3
If you need a line or parts, contact me thru email or 1-800-609-5110. Bill
8" CHANNEL IRON UP TO 25' LONG (A51247)
8" CHANNEL IRON UP...
UNUSED KIVEL QUICK ATTACH TRAILER MOVER (A51248)
UNUSED KIVEL QUICK...
2003 CATERPILLAR 277 SKID STEER (A51246)
2003 CATERPILLAR...
2014 International DuraStar 4300 Street Sweeper Truck (A52377)
2014 International...
2015 TAKEUCHI TB260 EXCAVATOR (A51246)
2015 TAKEUCHI...
UNUSED GREAT BEAR 78" HEAVY GRASS FORK GRAPPLE (A51248)
UNUSED GREAT BEAR...
