hydrolic issuse with jinma 254
   / hydrolic issuse with jinma 254 #1
house of klaus
ok
jinma 254
we have a jinma 254 tractor my husband recently got. there was some problems with hydrolics raising when he got it but tractor had been sitting covered for a while so he thought that was it. he got it home brush hogged a olittle then tried to push a dead tree down. the ground was wet and he was leaving ruts so he was going to wait until it dried up a bit. now the hydrolics won't lift again. he tried changing the hydrolic oil but no success. can anyone help?
   / hydrolic issuse with jinma 254 #2
Can you be a little more specific? What exactly won't lift, Loader or 3PH? THe first thing I would look to is that all the suction fittings between reservoir under the seat and the hydraulic pump up on the right side are tight. A little vacume leak along the suction will cause the pump to loose suction and stop drawing fluid. No fluid in = no fluid out so that would be where I would look first. After that there are a few things that can cause what you are experiencing, but we can discuss those after you are a little more specific about your symptoms.
the loader. but the back attachement area is not working as well. we tried to tighten all the hydrolic hoses but still no go on the hydrolics.
   / hydrolic issuse with jinma 254 #4
Do you have a pressure gauge on the hydraulic system to see what pressure is there?
RonJ
   / hydrolic issuse with jinma 254 #5
Sounds like a bad pump or pump shaft coupling.
How is the hydraulic fluid level and more importantly how is the engine oil level? If the pump fails many times it will blow the seal between the pump and engine dumping hydraulic fluid into the engine.
Chris
2015 Chevrolet Equinox SUV (A50324)
2015 Chevrolet...
2014 International Durastar 4300 Terex BT2047 47ft Crane Truck (A50323)
2014 International...
2019 CATERPILLAR 289D SKID STEER (A51242)
2019 CATERPILLAR...
2016 JLG ECOLIFT 70 SELF PROPELLED MANLIFT (A51242)
2016 JLG ECOLIFT...
2011 Ford Ranger Pickup Truck (A50323)
2011 Ford Ranger...
2014 Dodge Avenger Sedan (A50324)
2014 Dodge Avenger...
