hydrolic backhoe question will it work?
/ hydrolic backhoe question will it work? #1
cc1840
Hello please bare with me I'm a novice to Hydrolics
I have a old Brantly backhoe and want to put it on my case 1840
mounting is no problem
The brantley operates at 1800 psi dont know the gpm
my skidsteer puts out 15 gpm at 2300psi at the aux hook up
Is there an way I can use the aux hydrolics on the skidsteer to run the backhoe?
If so what do I need to get
thanks
/ hydrolic backhoe question will it work? #2
G'day and welcome to TBN you should be able to plug straight into your aux hyd you will need to check that you have a relief in your b/h controls to limit it to 1800 psi if not you can fit them inline with a bit of plumbing. Gpm should not worry you as it will only affect the speed of operation. Good luck with it and remember we like pics of your projects
Jon
Thank's guys
the BH has a built in bypass relief in the control valves
I will put some pics up when I have it attached
Once again thank you!!!
1993 International 4900 Ram Rodder Combination Sewer Jetter Vacuum Truck (A64194)
1993 International...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
2022 CATERPILLAR 289D3 SKID STEER (A65053)
2022 CATERPILLAR...
ALKOTA HOT/COLD PRESSURE WASHER (A65055)
ALKOTA HOT/COLD...
UNUSED RAYTREE RMSC78-78" HYD SOIL CONDITIONER (A65055)
UNUSED RAYTREE...
2008 Allmand Max-Lite ML20 20KW Towable Light Tower (A64194)
2008 Allmand...
