hydrolic backhoe question will it work?
   / hydrolic backhoe question will it work? #1
cc1840
Hello please bare with me I'm a novice to Hydrolics
I have a old Brantly backhoe and want to put it on my case 1840
mounting is no problem
The brantley operates at 1800 psi dont know the gpm
my skidsteer puts out 15 gpm at 2300psi at the aux hook up
Is there an way I can use the aux hydrolics on the skidsteer to run the backhoe?
If so what do I need to get
thanks
   / hydrolic backhoe question will it work? #2
G'day and welcome to TBN you should be able to plug straight into your aux hyd you will need to check that you have a relief in your b/h controls to limit it to 1800 psi if not you can fit them inline with a bit of plumbing. Gpm should not worry you as it will only affect the speed of operation. Good luck with it and remember we like pics of your projects
Jon
Thank's guys
the BH has a built in bypass relief in the control valves
I will put some pics up when I have it attached
Once again thank you!!!
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
2011 Nissan Rogue SUV (A53424)
2011 Nissan Rogue...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A53473)
2022 MAXXD BD14...
2017 Makita HM1307CB 35lb Demolition Hammer (A52377)
2017 Makita...
UNUSED Grey Waterproof PE Tarpaulin w/Grommets (A53117)
UNUSED Grey...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
