Hydrogen from water to get 25% more mpg in gas engine.
   / Hydrogen from water to get 25% more mpg in gas engine. #1
coffeeman
Platinum Member
Hi there
Here we go again.
Guy claims to improve gas milage about 25% extracting hydrogen from water as we drive. I guess it's a scam. What do you folks think?
BMC Introduces the H²O Atomizer
Something is gonna happen in the form of a breakthrough. There are a lot of people now working on things. probably the best will come from someones back yard garage.
Cheers
   / Hydrogen from water to get 25% more mpg in gas engine. #2
Even if it only took (it doesn't) the same amount of energy to split water into hydrogen and oxygen as you would get back recombining it back into water by burning it in your engine the net energy gain would be zero.
Considering that their conversion process, your engine and alternator are all less than 100% efficient it sounds like the best you could hope for would be not to ruin your engine.
There was a water spray used in aircraft engines around WW2 but I believe that it was to cool combustion during full throttle to prevent detonation (knock) & did not split the water into hydrogen & oxygen.
Your mileage may vary
   / Hydrogen from water to get 25% more mpg in gas engine. #3
The AV8-B Harrier Jump Jet uses water injection to cool the jet engine while in hover. It only carries enough water for a couple of minutes of hover though.
This looks like a great big scam to me. The fact that it says it only uses a pint of water for every few thousand miles just sounds like it can't possibly be producing enough H2 to be useful as a fuel.
   / Hydrogen from water to get 25% more mpg in gas engine. #4
I was all set to order a unit for my tractor when I noticed it require 25 amps and the tractor dynamo only puts out 15 amps. Bummer:eek:
   / Hydrogen from water to get 25% more mpg in gas engine. #5
you got a better chance of running you engine by converting beans into methane.
I kinda agree will all of the above. So, how do they get away with it? I think my son-in-law ran across this offer because they are selling one on Ebay. I'm not sure though.
About 30 years ago I read a newspaper article about some guy who had done something to a small ford that improved his gas mileage to like 70 mpg. It was reported he drove from Titusville, Fla. to Washington D.C, He wanted to show it to Congress or something like that. I never heard anything since. Of course, the story always: Some oil company bought the idea and buried it. Sometime you just wonder.
Cheers
   / Hydrogen from water to get 25% more mpg in gas engine. #7
This country was built on scams--Social Security, for instance. That's what makes it so great...scams are limited only by human imagination and gullibility (which is apparently unlimited).
   / Hydrogen from water to get 25% more mpg in gas engine. #8
Social security a scam? :) :) "Dang, they're on to me."
How about the ultimate scam: fractional reserve banking. I think we should go back to male deer hides. At least they were always worth a buck.
   / Hydrogen from water to get 25% more mpg in gas engine. #9
Well....there is no reason that you can't split water into hydrogen. It's done all the time. All it takes is energy. If you could harness the wasted energy that an engine produces to split water into hydrogen then you could have a container of hydrogen. What you would use the hydrogen for in a diesel engine, I have no idea. My Kubota burns diesel, not hydrogen. Hmmm....maybe you could carry around an oxidizer and turn your tractor into a rocket, lol.... Hmmm...what size nozzle do I need for that?
   / Hydrogen from water to get 25% more mpg in gas engine. #10
Bruce Crower of Crower Cams has been working on a 6 stroke engine. It adds two strokes to a conventional engine in which water is injected into the cylinder thereby turning the additional two strokes into (more or less) a steam engine.
Directory:Crower's Six-Stroke Engine - PESWiki
There is actually alot of interesting technology going on in the engine field. Everything from modern steam engines to 92 % efficient gun engines to almost 100% efficient Rotary Compressed-Air Motor's.
Directory:Engines - PESWiki
2010 Club Car Electric Cart (A53424)
2010 Club Car...
2015 Ram 3500 Enclosed Service Truck (A52377)
2015 Ram 3500...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
2013 Cadillac SRX SUV (A53424)
2013 Cadillac SRX...
2019 FREIGHTLINER SPRINTER 2500 CARGO VAN (A54313)
2019 FREIGHTLINER...
Ford F-450 Utility Truck (A55218)
Ford F-450 Utility...
