Hydro vs SS for 45 HP Compact Tractor
   / Hydro vs SS for 45 HP Compact Tractor #11
Love the hydro on my new tractor
It makes tractor life so much easier. And much easier on my surgically repaired ankle, and knee than pressing a clutch.
Also I can have my kids pull the tractor forwards and back it up while hooking up implements Like a trailer, the baler and Haybine, with less stress.
   / Hydro vs SS for 45 HP Compact Tractor #12
Not sure about other brands but my Kubota GST has a hydraulic clutch shuttle shift and you never touch the foot clutch to do any shifting. The FST and GST Kubota transmissions are fully synchronized so you do all shifting while on the move.
David
I have a stupid question. If you never have to use the clutch for shifting on GST/FST tractors then why do they have clutches? I don't get it.
   / Hydro vs SS for 45 HP Compact Tractor #13
Call me old fashioned but I still prefer the shuttle Now understand I have really nothing bad to say about a HST as they work and work good and seem to hold up for a good long time but for me doing long runs threw the field its much better to simply use the gear than the HST. It uses less fuel, seems to be less noisy and when in areas where speed isn't going to be constant its much less stress on my knee pushing the throttle than any HST pedal I have ever used. The gear also hold more power and doesn't drop nearly the same amount of speed gong up as the HST's I have owned.
Now many will argue some of the things I point out but this is my experience and remember I own both and have owned many of each as well as the same brand and size with one being HST and the other being gear.
Now what is best for your needs will depend on You, your property and the particular jobs you have for the tractor.
Some of the folks who still have and prefer the gear are just simply put born operators who have a feel for machinery and just seem to become one with the machine. Remember not everyone is able to be a top race car driver so be honest with yourself about this as it really is the biggest factor IMHO!
Everyone has different property and I would bet the person telling you to go gear has some big long runs with gentle turns and runs at a set constant speed for hours at a time. This is where the gear will excel but be assured that an operator with a good feel for machinery will run all but side by side with a HST where the short runs and loader work are concerned and some will be even faster and get closer making it look like kids play but again are you a "born operator" ?
Most of the folks here choose HST for a reason and those who argue productivity are somewhat correct but if I remember the sales pitch back in the day, wasn't that they were faster it was that I could get more from a poor operator and had less frustration looking for good operators who wouldn't break everything or burn out clutches. There was lots of truth in this then and there still is today.
I would be using it to scrape gravel driveways, haul much around the yard, plug and seed yard. Might occasionally use loader/box scrape to fix go-kart track. Prob have 2 - 2 1/2 acres of grass.
   / Hydro vs SS for 45 HP Compact Tractor #15
I would go HST for that.
   / Hydro vs SS for 45 HP Compact Tractor #16
I would probably suggest a HST with such a small lot to cut.
   / Hydro vs SS for 45 HP Compact Tractor #17
The BX series tractors and some of the B series HST tractors do not use a clutch either but have a bell housing type transition.
As far as the Grand L series having clutches other then the FST(fully synchronized transmission) needing the clutch Kubota offers 3 transmission choices and I think it provides a universal interface.
Every once in a while you have hit the clutch to shut everything down in an emergency but not required very often and that may be the purpose that the clutches are there for users not familiar with the drive system.
David
   / Hydro vs SS for 45 HP Compact Tractor #19
Hydro for your listed needs. Gear if your going to almost exclusively run a plow/disk. I've owned both.
So you think the hydro would hold up just as well?
2013 Jeep Wrangler 4X4 SUV (A55853)
2013 Jeep Wrangler...
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2015 GMC Terrain SUV (A56859)
2015 GMC Terrain...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
2014 Nissan Rogue Select SUV (A55853)
2014 Nissan Rogue...
Year: 2016 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A55853)
Year: 2016 Make...
