Hydro Travel pedal not coming back to netural
   / Hydro Travel pedal not coming back to netural #1
MESSMAKER
Veteran Member
Bluegrass,KY
DK4710SE
Had tractor in to have hydro tube replaced and after getting it back my travel pedal is not operating properly. Crawls forward with foot off pedal and will not start without playing with the pedal to get the safety switch to close. Is there an adjustment?
   / Hydro Travel pedal not coming back to netural #2
Yeah, mine doesn't aways return to the neutral position either. Close to it, but not quite.
   / Hydro Travel pedal not coming back to netural #3
On the Kubota, sometimes a little lube is needed under the floor on the pedal linkages..
   / Hydro Travel pedal not coming back to netural #4
Here is some info on the pedal not centering.
  • OneTouch Nov 29 2011 (2) (1).pdf
  • KMBT25020120321150700.pdf
Found the problem. Must have run over a small tree while bushogging. It bent the shaft that the shock hooks on. Had it in a slight bind. I unhooked the linkage and straightened the shaft. All is fine now.
2006 Ford F-550 4x4 Flatbed Pickup Truck (A50323)
2006 Ford F-550...
2011 FREIGHTLINER M2 26FT BOX TRUCK (A50505)
2011 FREIGHTLINER...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
CATERPILLAR 242D WHEELED SKID STEER (A51242)
CATERPILLAR 242D...
2011 L3 MEP-806B GENERATOR (A51222)
2011 L3 MEP-806B...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
1994 Mack CH613...
