Hydro Trans quit working!!!
   / Hydro Trans quit working!!! #11
Mrhiggins, I will start out first of all telling you I know nothing about your cub, but hydro's should have some type of replenishing valve in it's circuit to keep hydraulic oil to its pump. If you can find out where it is located maybe it is as simple as taking it out,clean with solvent, and make sure it is able to move free. The pump and motor are a closed loop system so your other hydraulics as you metioned are o.k. and that would feed to your hydro pump as some one else mentioned. It sounds to me air is in there and it needs bled out or it will chew your pump up. Remember clean everything around anything you open very clean, 1 spec of dirt could have been culprit.
Isn't there a by-pass valve located in the circuit, used for towing???
Transmission has a shift lever, High, Low and Neutral. The neutral position works ok. I can push tractor forward and back.
   / Hydro Trans quit working!!! #13
Cub Cadet has a service number out there somewhere, or maybe just question your local cub dealer about problem. I think it is more of an air issue, but you will ruin pump if you keep trying it untill issue is addressed.
MMurphy...I agree about not runnung the tractor till I can get some more definate conclusions about the problem. I did talk to the dealer when it first happened and his opinion was the same as mine about moisture in the system. Some brands are very sensitive about that. At a shop rate of $75 per hr. I thought I would get some other opinions. Maybe someone had had the same problem.... I even read about guys having Cub replace the tranny a couple of times and even buying the tractors back. I really like the tractor but have had a few other problems, more than a quality tractor should have. When I get it fixed this time I will try to replace it. Maybe even another Cub now they are Yanmar.
Higgins
Well, the dealer came & picked up the tractor yesterday. Its their busy season so will probably be awhile before they can look at it. I'm anxious
to find out if it will be $500 or $5000 to fix it. A new hydro tranny at M&D
is $815.00 but it may not even be the tranny so I guess I'll have to wait for the diagnosis. I post it when I find out.
   / Hydro Trans quit working!!! #16
Good luck with that. It's hard to wait for news when you know that one the big end it could be very expensive. On the other hand, imagine how good you will feel if the solution is simple and inexpensive.
Hoping karma is on your side!
JN
Up-date on my 5234de that quit moving. A little background first. About 2 years ago a hydro line wore through because of bad routing too close to the 3-point lever. Lost a lot of fluid before I noticed it. Put a new hose on, changed the fluid. Then this winter while plowing snow it quit moving.
Just heard from the dealer, a bearing has gone out and the metal pieces have made a mess of everything. $3,000.00 to fix it. I'm still making payments on the tractor so I really don't have much choice but to pay to have it fixed. Cub won't help. I contacted them when the hose wore through and saved the e-mails just in case but they still won't help. Only have 400 hours on it. The tractor is probably only worth $3000.oo but can't buy anything new for that price. My dealer is great, said he would knock off 3 hours on the labor. Be careful on buying a used 5000 series Cub.
Got a call my 5234de is ready. Grass is getting thick so will be glad to get it back. I just wanted everyone in Mid-Michigan to know what a great dealer Atherton Road Sales is. They knocked off 3 hours on the labor & did not charge me to pick-up & return my tractor. They felt bad about a tractor with only 400 hours having such a big problem & Cub not willing to help. They sell several other brands.
   / Hydro Trans quit working!!! #19
So, for $815 you can buy the trans ... but it will cost $3K to fix the problem.:confused2: Labor is too high!
larry
2023 PJ Dump Trailer (A55973)
2023 PJ Dump...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
NEW Thiessen Track Closer Disk (A56435)
NEW Thiessen Track...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2019 PJ TRAILER 32FT GOOSENECK (A55745)
2019 PJ TRAILER...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
