Hydro Tranny noise? Help??
/ Hydro Tranny noise? Help?? #1
Typhoon
Southern Illinois
LS MT357HC
Ok this is gonna be hard to describe, but I will try. My New Holland TC29D has 40 hours on it. All fluids are topped, I keep on top of the maintenance. However, just about a week ago, it started making a different noise. When the tractor is moving, (i.e. under a load), just going down the road, it makes this intermittent noise. The noise is hard to describe. Its like a mechanical squeal or something. It happens for like 1 second, then goes away for a couple seconds, then does it again, etc etc. It is rather loud and annoying. For the first 30 hours the tractor never made this noise. When the noise occurs, there is no other symptom. The tractor still runs fine, like a brand new one! No other symptoms at all. Just this intermittent noise. Like I said, it only happens when tractor is moving. Thanks for any input! Normally I would just haul it in to my dealer and have him check it out but the dealer is 45 miles away and I don't have a trailer for it yet. Thanks!
/ Hydro Tranny noise? Help?? #2
You can always hope the noise goes away, but I wouldn't hold my breath... /forums/images/graemlins/tongue.gif The only thing I can think of is a loose fan belt. Since your tractor is new, the fan belt could have loosened up. They can make a terrible squeal if the belt slips. That could also come and go as you describe. /forums/images/graemlins/confused.gif
/ Hydro Tranny noise? Help?? #3
There was a problem with the hyd filters on these models. They were too restrictive too flow and you would get that awful squall noise. They resoursed them, might be some of the old ones floating around.
Mine did it after they gave me the wrong filter.
Hercules Gun Safe Holds 20 Guns (A65583)
Hercules Gun Safe...
2007 Chevrolet Silverado 1500 Pickup Truck (A64194)
2007 Chevrolet...
(3) Steel Wheels (A65640)
(3) Steel Wheels...
6' Picnic Table (A66408)
6' Picnic Table...
2014 Chevrolet Equinox SUV (A64557)
2014 Chevrolet...
NexTier Frac Manifold T/A Trailer (A64194)
NexTier Frac...
