Hydro stat transmission whine
   / Hydro stat transmission whine #1
emileo
john deer 300 garden tractor
I have my 300 JD garden tractor fitted with a loader presently on blocks for lost of hydraulic pressure in the FEL will be checking that out soon but in the mean time I have a question about my HST whining when the tractor is under load is that normal ?
   / Hydro stat transmission whine #2
First, I would check filters and fluid levels. Ken Sweet
   / Hydro stat transmission whine #3
It would depend on your definition of "whine"
I think all hydrostat transmissions whine to an extent. Maybe you are low on fluid and that's why you have lost your loader hydraulics and have a severe whine?
   / Hydro stat transmission whine #4
I believe the FEL hydraulic is supplied oil by the HST charge pump. No FEL would point towards loss of flow which will make the HST noisy. Like Dave suggested, check the fluid level.
   / Hydro stat transmission whine #5
All 3 of the JDs with HST have had the whine. Guess if you don't like it, you gotta go to a 3 series or Kubota L series gear. LOTS heavier tractors. In most cases, you don't need all that weight. Take the HST whine.
Ralph
   / Hydro stat transmission whine #6
It seems most if not all HST tractors are prone to whine. Some fluids may cause less whine than others. Use what the manufacturer recommends. Avoid mixing different fluids.
   / Hydro stat transmission whine #7
That can't be true...
When I posted that I can't stand the whine of those whiner transmissions, numerous folks here "claimed" THEIR tractors had NO whine at all!! Of course, they are the same guys that say, HUH?? all the time! lol lol
SR
   / Hydro stat transmission whine #8
SR
I know you don’t believe it and probably never will but some HST trans don’t whine. I’ve had 2 HST+ Kubotas and they neither one whine. The cheaper economy grade Kubotas whine terrible. And my hearing is fine. What about your HST dozer. Does it make the dreaded whine?
I know you don稚 believe it and probably never will but some HST trans don稚 whine. I致e had 2 HST+ Kubotas and they Th one whine. The cheaper economy grade Kubotas whine terrible. And my hearing is fine. What about your HST dozer. Does it make the dreaded whine?
The fluid is fine I top it up last fall with JD Hy guard when I change the filter not sure what type was in there but it didn't make any difference with the whining which for me seems a little to loud . and by the way I found why I lost the pressure to the FEL the key from the coupling driving the pump sheard off. FYI the FEL on this tractor does not get its pressure from the transmission but it dose drive the hydraulic pump, I know very confusing . (This tractor is a mutt lol has kubota orange rear rims ,a very well made custom loader and a Honda 20hp motor
:confused2:
   / Hydro stat transmission whine #10
My previous New Holland 1925 hydro had no whine at all. My neighbor has a NH TC30 and it screams so loud it sounds like it's going to fly apart.....I can hear it 1/2 mile up the road at my house....seriously. Dealer said nothing is wrong with it. Another neighbor with a Kubota HST, no whine.
2025 CFG Industrial QK20R (A50123)
2025 CFG...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
2016 CATERPILLAR 277D SKID STEER (A51246)
2016 CATERPILLAR...
UNUSED INDUSTRIAS AMERICA L6 HYD LAND LEVELER (A51247)
UNUSED INDUSTRIAS...
(4) 250/80-15 Solid Forklift Tires (A52384)
(4) 250/80-15...
