Hydro pedal dampening cylinder worn, abrupt pedal movement ? BX22
   / Hydro pedal dampening cylinder worn, abrupt pedal movement ? BX22 #1
LuckyPierre
TDY Mass
BX22
After adjusting the brakes on my new BX22 last night I started at looking at the HST pedal mechanism. I noticed it stopped and reversed somewhat abruptly. I'm thinking it might be the gas charged dampening rod is weak being 15 years old.
also my seat belt mechanism won't lock, Kubota wants $140+ as they are sold in sets. any less expensive alternative ? Thanks :thumbsup:
   / Hydro pedal dampening cylinder worn, abrupt pedal movement ? BX22 #2
Quite remarkable how abrupt the trans operates without the damper. I've only experienced it once (on a JD) but it was an easy 'find'.
Seat belt - I'd fit OEM and check insurance implications if you were to fit anything 'else'.
Yes smooth is fast and safe...lol
Messicks had both items in stock and saved me $25. Will feel a bit safer now with a new oem working belt.
   / Hydro pedal dampening cylinder worn, abrupt pedal movement ? BX22 #5
Good job!
:drink:
I installed the new HST pedal damping rod yesterday, what a difference ! driving it feels I'm in an 'Eldorado' now. MY tractor only had 398 hrs on it, but it is 14 years. So old so if your HST pedal is stopping/starting abruptly suspect the damping rod has lost it's gas. :eek:
Komatsu 330 Excavator (A51573)
Komatsu 330...
2009 Pontiac G6 Sedan (A51694)
2009 Pontiac G6...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2021 FREIGHTLINER...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2019 JOHN DEERE 310SL HL BACKHOE (A51406)
2019 JOHN DEERE...
