Hydro fluid leaking up by seat
   / Hydro fluid leaking up by seat #1
Forrest1357
Marengo, IL.
John Deere 3720
I have a John Deere 3720 and I recently started having a substantial hydro leak which appears to be real close to being under the seat. I have a air ride seat and for the life of me cannot figure out how to remove it. Couple things I could use help on, 1st can anyone tell me how this thing is attached? and 2nd , what would be that high that would leak? The leak seems to be off center to the left.
   / Hydro fluid leaking up by seat #2
My 4300 has hydraulic lines right under the seat. I believe it might be for the 3 point. I have a small screen filter in the line so I changed it out when I changed hydro oil. It's not that hard to get to once you get seat off. I don't have air ride though. Just don't strip any threads on the hydraulic lines like it did.
3ft Metal 5-Point Star (A59231)
3ft Metal 5-Point...
Abaco Machines DVL500 Vacuum Lifter (A59230)
Abaco Machines...
RING 2 STARTS HERE @ 9:15 AM (A60430)
RING 2 STARTS HERE...
22FT Roadway Dry Van Pup Trailer (A56438)
22FT Roadway Dry...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
