Hydro couplers
/ Hydro couplers #1
boatpilot1
Glenarm, IL
bobcat CT450
Is there an adapter to convert the older style bigger pioneer fittings to the ones that are on compact tractors?
/ Hydro couplers
Maybe. Have to check my couplers. The ones that are on the compact tractor won't fit the style that were on my older bigger tractors. Was wondering if there was an adapter to hook them up to my compact? Thanks for your input.
/ Hydro couplers #4
We eventually just replaced the hose ends on our older equipment to the new pioneer style.
If you have lots of the old type plugs on equipment it may be easier to change the ones on the tractor to match or hydraulic shop could make a short pig tale adapter with the ends you need.
The only adapter I have seen goes from new style male to old style male, to use newer equipment on older tractors, you need the other way around.
/ Hydro couplers #5
I don't see why you can't make your own adapters... A couple male and female couplers and a couple pipe close niples or what ever you need to get them together...
Thankfully, everything comes with Pioneers today...
SR
2014 MAGNUM TRAILER (A68842)
2014 MAGNUM...
2012 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A67714)
2012 DRAGON 150...
HYUNDAI HL955 WHEEL LOADER (A65056)
HYUNDAI HL955...
2007 MACK GRANITE CTP713B DUMP TRUCK (A64280)
2007 MACK GRANITE...
2024 SANY 2Y26U EXCAVATOR (A65056)
2024 SANY 2Y26U...
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
