Backhoe Hydro Backhoe Thumb on 2465
   / Hydro Backhoe Thumb on 2465 #1
natem
Stonington CT
Kubota L-45
Was looking into getting a thumb for my kioti 2465 backhoe. Found that Michigan iron makes a hydro one, and manual. The hydro looks like the way I would like to go. Just dont know if it will be able to work with this backhoe and tractor, and how complicated it would be to install the hydraulics. Didn't know if any one has done this yet, or not??? I am planning to call them and get some more info on it.
   / Hydro Backhoe Thumb on 2465 #2
Call them, Bob at MIE is a prince of a guy and will walk you through the process. Their service is great. I have the manual thumb on my 2465 and find it very useful. I am not sure the hydraulic one would improve the usefulness on a small BH like ours. However, only you know what you want to do with it.
   / Hydro Backhoe Thumb on 2465 #3
I second Gil's comments. Those guys know what will fit and how it will fit on your machine.
Let me know how you make out; my 2465 is in the works.
Jon
Talked to them today, found that it is possible to hook up a hydro thumb but would cost around a grand. I think the manual thumb will do the trick for around $310.00 shipped.
   / Hydro Backhoe Thumb on 2465 #5
Your my kind of guy $1,000 Hyd vs $300 and a little effort----I always go with the $300.
Although, the older I get the easier it gets to expend money rather than effort.
   / Hydro Backhoe Thumb on 2465 #6
My thought would be a hyd thumb on a small machine would be a lot of stress on the hoe.
I went with manual.
Joel
   / Hydro Backhoe Thumb on 2465 #7
I paid more than $1800 for my hydraulic thumb, but think it was well worth it.
I can simulate what a mechanical thumb would do by setting the thumb in one position, and while that beats the heck out of no thumb, it is not nearly as good as the hydraulic.
Two things to think about:
1. Every time I dismount, especially on broken, rocky ground, which is where I will be using the thumb, there is a chance for a slip & fall accident. Adjusting a mechanical thumb is always going to be a little dangerous.
2. If I am moving rock for an appearance application, it is a lot easier to avoid scarring the good face of the rock with a hydraulic thumb.
   / Hydro Backhoe Thumb on 2465 #8
Maybe because I've always owned mechanical but I've never adjusted mine, it is either on or off.
Joel
   / Hydro Backhoe Thumb on 2465 #9
Joel
Joel over 2 years later do you still find you are doing fine with the manual thumb?
   / Hydro Backhoe Thumb on 2465 #10
last summer when I started looking for a thumb, I originally was going to to do just a mechanical thumb.
After talking with MIE, and looking how easy it would be to convert to a hydraulic thumb, I opted for the hydraulic unit.
If I rememeber right, it was only about $400 more for the hydraulic kit. And since I was traveling cross sountry, I was able to stop in and see everything in person, and ask all sorts of questions. Also, I didn't have to pay the shipping costs.
Installation was very simple and took about 2 hours. The kit has everything included. I did have a small issue once I got the thumb installed, but the great people at MIE worked with me over the phone to resolve the issue (bad quick disconnect couplers).
I haven't looked back since.
Marc
2008 Ford F-250 4x4 Knapheide Service Truck with Liftgate (A51692)
2008 Ford F-250...
2015 PETERBILT 567 TRI-AXLE (A52472)
2015 PETERBILT 567...
NEW LandHero Mini Stand up Skid Steer (A53002)
NEW LandHero Mini...
Truck Tool Box (A50774)
Truck Tool Box...
KJ 33'x25' Double Garage Steel Barn Shed (A50121)
KJ 33'x25' Double...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
