Hydro adjust knob
/ Hydro adjust knob #1
cj7
Zelienople, PA
L2500
My 3 point adjustment knob, located under the seat, will not turn any more. It seems to be stuck in one position. It will not turn either way. Any ides?
This is on an L2500
/ Hydro adjust knob #2
Spray it up with "PB-Blaster" that should break it loose. That stuff work really well.
/ Hydro adjust knob #3
The way that I have done it is to soak with PB Blaster where it goes into the housing. Let it soak for a couple of days. Then use a pair of vice grips very gently on the shaft.
/ Hydro adjust knob #5
It is really good stuff, napa sells it. I used it to bust a 4'' gate valve loose, I was impressed with its performance.
/ Hydro adjust knob #6
<font color="blue">What is PB Blaster? Some sort of penetrating oil? </font>
Yes, it is. I haven't bought WD-40 for a few years, because PB Blaster is that much better.
/ Hydro adjust knob
ok
thanks guys.. I'll soak here up some more...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
2014 CATERPILLAR 938K WHEEL LOADER (A64279)
2014 CATERPILLAR...
2022 EZ-GO ELITE...
Front Tank Bracket (A64127)
Front Tank Bracket...
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
Unverferth Perfecta II (A64126)
Unverferth...
