hydrlic problem with my 321s
/ hydrlic problem with my 321s #1
hlndeerhunter
I bought a 97 321 the problem I am having is the lift goes up very well but will not come down without a good bit of weight on it 200 plus lbs. What could be my problem. /forums/images/graemlins/confused.gif
/ hydrlic problem with my 321s #2
I'm not familiar with your tractor. Does it have an adjustment valve somewhere (usually near the floor in front of the seat) to control the rate of flow of hyd fluid, and control speed of implements dropping?
/ hydrlic problem with my 321s #3
I believe that is has a rate of drop control on the right hand side below your seat. Look at the side of the housing for a round cover with a lever. That should adjust your rate of drop. Also, make sure you do not have the control lever in the up position and that you are not raising the implement with the draft lever.
Your right I got the tractor Monday an went to work Tuesday. Got a call from my son on the problem an located this site (great place to find) /forums/images/graemlins/tongue.gif
YALE 60 MX STRAIGHT MAST FORKLIFT (A63276)
YALE 60 MX...
2022 John Deere X730 Lawn Mower (A63116)
2022 John Deere...
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
PRIEFERT PORTABLE CATTLE SQUEEZE CHUTE (A64277)
PRIEFERT PORTABLE...
3269 (A63117)
3269 (A63117)
2012 FREIGHTLINER 114SD ROLLOFF TRUCK (A59909)
2012 FREIGHTLINER...
