hydrlic problem with my 321s
   / hydrlic problem with my 321s #1
hlndeerhunter
I bought a 97 321 the problem I am having is the lift goes up very well but will not come down without a good bit of weight on it 200 plus lbs. What could be my problem. /forums/images/graemlins/confused.gif
   / hydrlic problem with my 321s #2
I'm not familiar with your tractor. Does it have an adjustment valve somewhere (usually near the floor in front of the seat) to control the rate of flow of hyd fluid, and control speed of implements dropping?
   / hydrlic problem with my 321s #3
I believe that is has a rate of drop control on the right hand side below your seat. Look at the side of the housing for a round cover with a lever. That should adjust your rate of drop. Also, make sure you do not have the control lever in the up position and that you are not raising the implement with the draft lever.
Your right I got the tractor Monday an went to work Tuesday. Got a call from my son on the problem an located this site (great place to find) /forums/images/graemlins/tongue.gif
Case 580B Backhoe   (A52384)
Case 580B Backhoe...
2024 CATERPILLAR 255 SKID STEER (A51242)
2024 CATERPILLAR...
Toro Z-Master 7000 Series 70in Zero Turn Mower (A50322)
Toro Z-Master 7000...
UNUSED AGT SKID STEER QUICK ATTACH SEEDER DRILL (A51244)
UNUSED AGT SKID...
CASE IH MAGNUM 180 TRACTOR (A51243)
CASE IH MAGNUM 180...
UNUSED FUTURE RC BOOM TRUCK TOY (A51243)
UNUSED FUTURE RC...
