hydraulics?????
/ hydraulics????? #1
djh1121
Louisville, MS
JD 4300
Can some teach me about hydraulics? What they do/mean, why you want one or the other or all, etc… of the following.
What is power beyond? Is rear auxiliary the same thing?
What does SCV mean?
What is a single SCV?
What is a third SCV?
What is a forth and fifth SCV?
Thanks,
Jason
/ hydraulics????? #2
Jason,
</font><font color="blue" class="small">( What is power beyond? Is rear auxiliary the same thing? )</font>
Power beyond is a pressure and return circuit designed to power an implement which has it's own control valves. Examples: backhoe, wood splitter, post driver.
The power beyond expects the implement to provide the control valve(s) as it has none of it's own.
I'm not familiar with the term "rear auxiliary". Maybe someone else will jump in and help me out.
</font><font color="blue" class="small">( What does SCV mean? )</font>
SCV is an acronym for Selective Control Valve. A valve used to operate a hydraulic circuit. A front end loader ordinarily utilizes a Dual Selective Control Valve (DSCV) to control the boom and the bucket curl. This valve bank can be controlled by two separate levers or by a joystick whose design allows a single lever to control both functions.
</font><font color="blue" class="small">( What is a single SCV? )</font>
A single spool valve used to control one hydraulic circuit.
</font><font color="blue" class="small">( What is a third SCV? )</font>
When a tractor is equiped with a DSCV, it is sometimes necessary to control a third hydraulic circuit, such as a mid mount mower or an implement that has a remote cylinder. To enable this, a third SCV is installed.
In the case of the mid frame 4000 series John Deere CUT's like yours and mine, the actual valve is built into the DSCV (which is really a three spool valve). To add the third SCV capability, a kit is installed which consists of 1) a control lever mounted remotely on the right fender and connected to the third spool of the DSCV by a cable and 2) the necessary piping to route the hydraulics from the valve body to the rear of the tractor.
</font><font color="blue" class="small">( What is a forth and fifth SCV? )</font>
Two additional control circuits. The circuits can be created by adding diverter valves to the existing DSCV circuits or by adding additional valves. In the case of your 4300, Deere uses electrically operated diverter valves and the DSCV circuits controlled by the joystick control. Other tractors may require different strategies.
/ hydraulics????? #3
</font><font color="blue" class="small">( I'm not familiar with the term "rear auxiliary". Maybe someone else will jump in and help me out. )</font>
"Rear auxiliary" or "rear remote" on my Kubota is to operate hydraulically operated rear implements. In the case of my BX22, this is </font><font color="blue" class="small">( a singe remote valve that is designed as a sectional/ stackable valve allowing for expansion if required. It is available as an detent valve section or a float valve section. The valve kit requires a hose kit to complete the installation. The valve uses the tractor hydraulics to operate optional implements. The Maximum flow rate available at the remote is 3.7 gallons per minute (gpm).)</font>..... From Kubota Product Information Bulletin PIB-2003-019 Dated:06/09/2003... Hope that this helps and is the information that you are looking for.... Junk...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59910)
2018 FREIGHTLINER...
2012 WESTERN STAR  4900SA  SLEEPER (A63569)
2012 WESTERN STAR...
211771 (A63276)
211771 (A63276)
Flex King KM 7 Section V Plow (A63118)
Flex King KM 7...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
